Solution to Nest causing reverse valve to click on heat pump?
Capsize2929
9 REPLIES 9
Hello Capsize2929,
Thanks for reaching out to the Google Nest Community Forum.
Power-related issues are one of the main reasons for the odd behavior of the Heat pump's reversing valve. Usually, this happens with incorrect configurations during initial setup, compatibility or with the wiring itself. Could you please give us your thermostat's power readouts in its Technical Info settings? Also, when did you install your Nest Thermostat?
Chiming in — I just want to check if you managed to see the response above. Please share with us the needed information, as it will help us to move forward.
I appreciate your help, Mark.
Capsize2929
Hi, thanks for the follow ups. We swapped the thermostat for another nest thermostat and it is fine now. Not sure what setting could be causing the reverse valve to be clicking like this. If anyone knows, please post it because there are several threads that lead to this unanswered question on this forum.
Capsize2929
OK -- I still want to use this problematic thermostat. Here are the technical readings:
Battery: 3.783V (I just plugged it in)
Voc: 34.82V
Vin: 34.82V
lin: 200mA(c)
I tried a factory reset with this device and moved it to an entirely different A/C unit, but the problem persists. I suspect that this nest unit in particular is defective
Hi Capsize2929,
I appreciate you keeping us in the loop, and I'm sorry to hear the issue still persists. We'd be happy to take a look at this for you.
Could you please fill out this form with the needed information? A member of our senior support team will be in touch over email to help.
Checking back in — how's it going? Have you managed to fill out the form? Let us know once you're done.
Hello Capsize2929,
I wanted to see if you had submitted the form. Let us know so we can move forward.
Hi Mark,
I returned the device as defective so I no longer have an issue.
Thanks
EdmondB
We understand. If you ever change your mind, we'll be here to help.
Edmond
