07-25-2022 12:49 PM
I currently use a remote sensor to register the ambient temperature in the room. Every once in a while, there will be a glitch and the temperature sensor reverts to the using thermostat instead of the remote sensor. On both the app (iOS) and the base thermostat, the remote sensor is selected, but the unit is still using the thermostat ambient temperature reading instead of the remote sensor. I try to toggle back and forth between the thermostat and the remote sensor, but it does not solve the issue. The only solution is to reset the thermostat. Has anyone else had this issue?
08-18-2022 11:27 AM
Hey there d_cappy,
I apologize about the late response, thank you for being patient! Were you able to fix that Nest Temperature Sensor issue? If not, I'd be happy to help out, as I can imagine this can be pretty frustrating. Let me just ask you some questions about what's happening:
For now, I would check out this article on troubleshooting the sensor, as well as this article on setup, specifically the section on where to place the sensor.
Jeran
08-22-2022 10:46 AM
Hey d_cappy,
I wanted to check in and see if you managed to see Jeran's post. Please let me know if you have any questions from here. I would be happy to assist, and make sure you are good to go.
08-23-2022 11:00 AM
Hey d_cappy,
I am glad to hear you are no longer running into the issue. I will keep the thread open for a couple of days to ensure everything is good to go from here. Please let me know if you have any other questions as well, as I would be happy to review.
08-26-2022 10:12 AM
Hey d_cappy,
I wanted to jump back in, and let you know that I will be locking the thread in 24 hours.
08-22-2022 01:02 PM
