Temperature offset
Renatoooo
There are some topics about this here, but all of them are closed for new comments.
As many users reported, my Nest Learning Thermostat is also reading 1.5~2°C higher than it should be.
I added 3 different thermometer next to it and ALL of them are reading 19.5~19.7°C, while Nest Learning Thermostat is reading 21.5°C
CLEARLY this is wrong and don't waste your time answering with links assuming it's correct, because it isn't. Also, I'm not stupid placing it in where there is heating or sunlight.
A feature with an offset temperature could be very helpful.
@Zouf, did you find any solution since your post from 1 year ago?
Zouf
Yes - I put an offset to my heating and cooling schedules 🙂
All kidding aside, no. I do believe Google has some deals with utilities to encourage energy savings, so I can understand they may be reluctant to let users calibrate the sensors.
Renatoooo
This product is very expensive to have a so unrealistic measurement of the temperature. Unbelievable!!
Renatoooo
Just a side note: looks like the sensor is probably near to the chipset or whatever, because the difference is much higher when the room temperature is <20°C
When the room temperature is 22°C, the Thermostat is measuring just 0.5°C higher.
Hello everyone,
Thank you for taking the time to let us know about your inquiry.
I appreciate your input, @Zouf.
@Renatoooo, I understand your frustration with the temperature discrepancy on your Nest Learning Thermostat. It can be frustrating when the device doesn't align with other thermometers in the same environment.
Your suggestion for a feature with an offset temperature is interesting and could be a valuable addition. Feedback from users like yourself is crucial for the improvement of products, so consider sharing your experience and suggestions directly with our Product Specialists.
If there's anything else I can help you with, feel free to let me know.
