The cold and heat are running
robertnesbit
The cold and the heat is on at the same. I have a bad thermostat
@robertnesbit
Which Nest thermostat do you have?
Is this problem new, or was it there since the thermostat was installed?
Can you post a picture of the original thermostat wiring?
Thanks for reaching out. I just want to check if you managed to see the response above. Please share with us the needed information, as it will help us to move forward.
Hi robertnesbit,
Regrads,
Hey robertnesbit,
