Thermostat needs manual charging & network connectivity issues all of a sudden
msabhi
Tried all the approaches recommended in this forum to get the wifi connectivity, but failed miserably. This failed end of its 2nd year and I discovered this forum recently (a year later) and need help getting it fixed.
luciaaa
Hi, @msabhi,
Thank you so much for reaching out to the community. I'm sorry to hear you're experiencing issues with your thermostat's battery and connectivity. I'm happy to assist you.
To better assist you, I have some questions related to your thermostat:
  • What type of thermostat do you have?
  • When did the issue start?
  • Are the power breakers on, and do you receive power to your home?
  • Do you see any power errors?
In the meantime, here are some initial troubleshooting steps you can try:
  • Remove the thermostat display from its base and check if any connector pins are bent.
  • Ensure all wires are securely fastened to their terminals and all buttons are fully pressed.
Keep me posted.
Ana
