08-26-2023 01:00 PM
Hi I am hooking up a new thermostat and it is saying no power to RC. There is 28 volts to this and the wire is straight.
08-30-2023 02:34 PM
Hi MarahD,
Thanks for reaching out. I'm sorry for the delay. I'd like to know more about it. Could you please provide your Nest Learning Thermostat power readout? Check your thermostat wiring diagram. Also, ensure that the wires are properly stripped and seated in the thermostat base.
You can follow these guides:
Thermostat power readings:
Thermostat wiring diagram:
Check your thermostat wires:
