Trying to Figure Out Compatibility with Dual Zone Single System
Stevenpeven
My wife and I just purchased a home and we are trying to figure out if our nests will be compatible. The system is set up as dual zone, but there is only one furnace and one AC unit. I'm thinking yes, but just want to double check with someone who has more expertise.
Below are photos of the current thermostat and zone setup
https://photos.app.goo.gl/zSooyCABmXE2QPG79
https://photos.app.goo.gl/vLfrtdKAq1Auszyw5
https://photos.app.goo.gl/Bts9AHMFYDdNHA8j9
https://photos.app.goo.gl/rq19Bw7jUD3t5pgU8
https://photos.app.goo.gl/X3KEqAy4mwQyDYpP7
8 REPLIES 8
You have a nice 4-zone system that is only compatible with the Nest Learning Thermostat, 3rd Gen.
Can you post a picture of the zone controller wiring? The cover will pop off.
Do you know if it is a conventional or a heat pump system?
WickedSydney
Our house is a single AC unit with multiple zones we just set up our first nest. It only controls the zone it is in but so far so good!
When you have multiple zone HVAC system, you will have multiple thermostats in the house and a zone controller located near the air handler unit.  For multiple zone systems you will need a nest thermostat for each of the thermostats in the house.
Ken, The AC Cooling Wizard
Stevenpeven
Thank you all for your answers!
@Patrick_Caezza It is a conventional system. Please see the zone controller wiring below
https://photos.app.goo.gl/2iueWCYghhmd5gxR8
@Stevenpeven
Thank you for the picture.
Your current system is compatible with the Nest Learning Thermostats, 3rd Gen.
Try this wiring.
Red - R to Rc (no jumpers needed)
Blue - C to C
White - W1 to W1
Gray - W2 to W2
Yellow - Y1 to Y1
Black - Y2 to Y2
Green - G to G
Thanks for the help Patrick_Caezza, and CoolingWizard.
Stevenpeven
Got it figured out, thanks!
I am glad to hear you are good to go from here. With that being the case, I am going to go ahead and lock the thread in 24 hours. Please let me know if you have any other questions from here, as I would be happy to take a closer look.
