11-18-2022 04:38 PM
Hi all, so I've had a potentially ongoing issue. Today when I got home the temperature had dropped to 65 deg with the thermostat set to 70. I received a message saying there was a potential issue because the heat was on but the temperature had dropped throughout the day. I went outside and the outdoor unit was not running despite the thermostat requesting heat. This has happened before so I turned off the heat and checked the filter in the indoor unit. In the past I've neglected filter changes resulting in a very dirty filter, changing the filter and turning the heat back on resolved the issue. This time the filter was clean. I turned the heat back on and I could hear the outdoor unit start, all is good. I'm wondering if there is a software issue with the tstat and replacing the filter wasn't actually the fix, cycling the heat on/off was. Has anyone experienced this? I did a brief search with no luck. Thanks
11-24-2022 11:31 AM
Hello GMazz1,,
I'm sorry for the trouble this may have caused you — let's see what's going on.
To isolate:
12-01-2022 10:54 AM
I wanted to check in and see if you managed to see Mark's post. Please let me know if you have any questions from here. I would be happy to assist, and make sure you are good to go.
12-02-2022 10:49 AM
12-02-2022 10:58 AM
Thanks for the replies. No error codes, no maintenance. I will have to check on the model, wiring, and power readouts when I get home. Thanks
12-05-2022 11:52 AM
I wanted to check in and see if you are still in need of any help. Were you able to check which model you own? Please let me know, as I would be happy to assist, and answer any questions you may have.
12-05-2022 05:30 PM
Display model 3.4 backplate model 5.4
Equipment sensed on Y1-G-O/B-W2-/AUX-Rc-*
Is that the info you need? Thanks for the help
12-22-2022 11:50 AM
Hi GMazz1,
I know it's been awhile, and I'm sorry for the delayed response. How's it going with your thermostat? Are you still experiencing the same issue?
Please let us know so we can assist you right away.
12-22-2022 12:10 PM
Mark, the issue has not happened again. It's very infrequent, I'd say it's happened 4 or 5 times over 3 years or so.
12-25-2022 11:12 AM
Hello there,
That's good to know, GMazz1. I checked on this, and here's what I found. It appears that you might need a common wire, which is a wire that's dedicated to delivering constant power and stabilizing the flow of current into the thermostat. Here's your reference to learn more about how common wire helps.
Let me know if you have more questions.
12-28-2022 01:36 PM
Hello GMazz1
I'm checking back in, and I wanted to ensure that everything is covered here. Please let us know if you have any other questions or concerns.
12-28-2022 05:19 PM
Thanks for your help, much appreciated. I'll look into hooking up the common wire and hopefully won't have anymore problems.
01-03-2023 02:18 PM
Hey GMazz1,
Fingers crossed! Let us know if you have other questions, we're here to help.
Archie
01-09-2023 09:44 PM
Archie
