Turn hot water on using Google assistant (voice) and nest learning thermostat
Corfty
I can't use Google Assistant (voice commands) to turn the hot water on and off.
The heating can be turned on and off using voice commands not problem
Is this command. It available? Or am I doing something wrong?
Nest learning thermostat.
AlexD
Thanks for reaching out here @Corfty . I would be happy to try and assist.
No worries, you're not missing anything. Hot water control is currently not available for the Assistant commands. You can check out Use Google Assistant with Nest products page to see what commands are available.
11 REPLIES 11
AlexD
Corfty
Thanks Alex, do you know if this is planned to be added and when? Seems odd to not have this built in.
AlexD
I don't have any information on this at the moment. Should there be any update, rest assured we'll let everyone know on our official channels.
Add-hot-water
This is a miss that voice control (via either Google or Alexa) for hot water is not available for the Nest Thermostat 3rd gen - why aren’t development teams working on this? - it’s clearly something the community wants!
Agreed. It's very odd, there are two core functions. heating and hot water and only heating is voice controllable!
Vladut
Hi @Corfty @Add-hot-water ,
Thank you so much for all the details. At the moment this feature it's not available but please check our support page for updates.
Vladut
Hi there, just checking in with you. Do you still need help?
Corfty
No as there's nothing to help with as you have said the ability to turn the hot water on and off with your voice is not available and not on the roadmap.
Add-hot-water
Hi Vladut, can someone in Google please raise this as a development ticket so progress can be tracked? Simply referring to the support page for updates is not progressing anything - judging by some of the previous threads on this that has been the response for a number of years now. Thanks
TudorL
Hi there, we can try to raise the feedback to our Seniors in order to forward it to the Dev team. Additionally, if you have any suggestion or feedback about our products, you can fill in this form as well: https://goo.gle/3KezjUf
Vladut
I'm so sorry for any inconvenience caused by this. I can take this feedback with me. Let me know if you need anything else.
