Upstairs system will not work unless downstairs system is working
Stickymint
As it says in the subject my upstairs heating will not work unless the downstairs in heating up.
The upstairs is set to come on 1 hour before the downstairs, however, the upstairs will not start heating up until the downstairs starts heating up..
Also if i try override the upstairs during the day when no heating is on at all, it doesn't.  What is frustrating in that the up stairs thermostat in these instances is showing orange as if it is providing heat - but it isn't.
What is wrong?
Hello Stickymint,
I'm sorry for the late reply and for the trouble this may have caused you — let's see what's going on.
To isolate:
  • What type of Nest Thermostats do you have?
  • Do you have a zoning system?
  • What type of furnace do you have? (gas, electric, etc.)
  • Did the heating ever work with the upstairs thermostat?
  • Did you select the correct fuel type?
  • Do they have a C wire?
  • Please check the power status for battery level, voc, vin, and lin under technical info settings.
Jeran
Thank you for helping out on this thread, Mark!
Hey there Stickymint,
I'm just checking up on this thread, do you have any more questions or need any additional help?
Jeran
Stickymint
Hi Jeran & Mark
2 x Nest learning thermostats
Yes, downstairs and upstairs
Gas - Worcester Bosch Greenstar CDi Classic regular, condensing boiler
It only works when the downstairs is providing heat
How do I check this
Don't know what you mean
                  Downstairs        Upstairs
Battery level            3.934v            3.950v
Vusb                     0.03v           5.01v
Vin                     10.97v                         0.00v   
lin                         200mA           200mA
Let me know what you think is wrong.
Mick
