Wiring Help for W/E and W2 wires with jumper
garrett16
I know to ignore the jumper wire but this system has me a little confused with what to do with the wire that is currently on W/E and W2. I have a heat pump system one of these is for the emergency heating element but I am unsure what I should do with the brown wire going into W2IMG_0193.jpeg
2 REPLIES 2
Sparkdizzy
I have the exact same setup as Garrett16, and the same question.  Trying to convert to Nest Learning Thermostat.  Any help on this topic could kill 2 birds with 1 stone!  Thanks so much.
RenzJ
Thanks for posting here in the Google Nest Community forum. I'd be happy to shed some light on your situation here. Our Nest Thermostat has an E terminal for emergency heating. We’ll be able to give you guys a wiring diagram for your setup if you could also send us a photo of your HVAC control board wiring.
If the other end of the wire is connected to the E terminal on your HVAC, you can connect it to the E terminal of the Nest Thermostat and set it up as emergency heating during the setup stage.
Keep us posted.
Renz
