Wiring and Config options for Heat Pump with Air Handler PLUS Oil furnace with forced hot water
cplewis
We used to have central air for cooling and oil furnace with forced hot water baseboards for heat. Last year we replaced our central air conditioner with a heat pump. I have had difficulty getting a clear answer on my options for configuring the nest to control two separate heating sources.
What are my options for configuring nest learning thermostat (3rd gen) with a heat pump and an oil furnace with force hot water heat. At a minimum, I want the oil furnace to be available for backup (manually triggered). If possible, it would be nice to automatically switch over in certain conditions.
Heat pump: Y1, G, O/B, Rc, C (these are connected to nest and it's working great for heating and cooling)
What are my options for connecting the oil system with two wires: R, W
zoeuvre
Hi cplewis,
Thanks for posting. For the R and W wires, these should be connected to the Nest Learning Thermostat's base as R to RH terminal and W to W1 terminal, respectively.
Let us know if you have any other questions.
