Y1 no power due to building shut down AC service during winter and voltage come out from Y1 is 0
fredwon227
Hello
Just bought nest thermalstat today and try to connect. The building I live at there is no AC so the voltage I measure from Y1 is 0. Heat is on and was using honeywell thermalstat interface there is a switch button to switch from heat or cool. Is there any way to work around this situation or not.
Please help out
Thanks
luciaaa
Hi, @fredwon227!
Thank you for reaching out to the community. I appreciate the detailed information you provided about your system. I understand that you have a heating-only system and the Y wire currently has no power.
To determine if your system is compatible with a Nest thermostat, please share a photo of your current wiring configuration on your Honeywell thermostat. This will help me assess the compatibility.
Please let me know if you have any other questions.
Ana
