blower fan turns off after 2 minutes when Nest starts cooling
paj70
I had an early model Nest for many years and replaced it over a year ago with a Nest Learning Thermostat.  I believe it worked fine all last summer, though it is possible I somehow never noticed as I have 2 HVAC units.  However, this summer I have noticed bad behavior.
What I have noticed since I turned it on heat/cool for the summer is that when the cooling cycle comes on, the inside fan blows for 2 minutes, then turns off, while the compressor and outside fan continue to run.  This is probably not good for the compressor.  Sometimes the inside fan will later start up again for a short period (probably 2 minutes again, but I was unable to time that one).
I have 4 wires coming from the controller board to the Nest:
Y on the board to Y1 on the Nest
G to G
W to W1
R to RH
Also on the board C and Y go to the AC unit.
What could be going on?
paj70
I found this similar issue:  https://www.googlenestcommunity.com/t5/Nest-Thermostats/blower-fan-turns-off-when-Nest-is-engaged-in...
OP never commented after original post, but someone else came in with the same issue.  The second guy said he eventually he solved it by installing a C wire.
I just paid someone $150 to come out and tell me that Nest was the problem.  Don't really want to spend another $150 to install new wire that has to run about 8 feet.  It should be pretty trivial to pull the new wire given that the thermostat one floor is directly above the furnace, running in an open interior wall.  But I'm not 100% confident in the wiring.  Do I just wire it exactly the same as it already is, but run the C wire from the one remaining open post on the C terminal to the C terminal on the Nest?
ovidioj
Hi @paj70,
Thanks for contacting us about the unusual behavior of your Nest Learning Thermostat. It's definitely not normal for the fan to shut off during a cooling cycle, and you're right, it could put a strain on your compressor. Based on the information you provided about the inside fan blowing for 2 minutes, then turning off while the compressor and outside fan continue to run, in this case, the recommendation would be to do maintenance since the compressor and outside fan are working. You should click on this link: Nest Pro HVAC technician near. To get assistance with your thermostat.
Please let me know how it goes or if you have any other questions.
Jorge
paj70
I tried to find a Nest Pro near me and could not, so I decided to just jump in, pull some new 18/5 wire and connect up a C.  It's been about 18 hours now and it seems to be working great!  So I guess, problem solved.  Nest should really just say they require, or at least highly recommend, a C wire!
ovidioj
Hi @paj70,
Thanks for posting in the community. I understand the frustration of not being able to find a Nest Pro readily available. It's great that you were able to get your Nest thermostat working by installing a C-wire yourself, and I'm happy to hear it's functioning well after 18 hours!
Your feedback about Nest thermostats clearly indicating the need for a C-wire is valuable. I appreciate you bringing this to our attention. In some cases, Nest thermostats can indeed work without a C-wire, but it can lead to unexpected behavior, as you experienced.
We're always looking for ways to improve our products and documentation. We'll take your feedback into consideration. To share your thoughts in more detail, you can use the feedback option within the Google Nest app or visit the submit feedback link. Thank you.
Please let me know if you have more questions or if there is anything else I can help you with.
Jorge
