10-24-2025 07:17 AM
10-27-2025 04:06 PM
Hi @elbloke1,
Thanks for contacting this community! I understand that your Nest Thermostat has this error code E299, about this error code I'd like to know more abut this, for that I'll ask you some questions:
This error code means that the C-wire is disconnected and isn’t able to provide power. The thermostat battery will power the thermostat temporarily, but the thermostat will eventually power off for that in the meantime I recommend you the following steps that may help:
Reinsert the C-wire:
Turn off the breakers > Remove > Reinsert the C-wire into the terminal.
Please feel free to share any additional details you think might be relevant.
Eduardo
10-27-2025 04:06 PM
Hi @elbloke1,
Eduardo
