09-17-2021 03:04 AM
Heat link is not working. No light showing. Boiler is working. There is power to the heat link
Help please
09-18-2021 01:51 AM
Hi @Barry.
I am sorry to hear your facing this behavior from your thermostat and am happy to try and assist you.
Make sure to check all breakers, just to make sure nothing has tripped first. If it all looks good power cycle the Heat Link. Turn the power off to the Heat Link, if you're comfortable in doing so, and turn it back on. Check to see if any LED comes on or if it has any reaction when you press the button on it.
AlexD
09-20-2021 05:44 AM
Hi @Barry , I wanted to check in.
Did you get the chance to try the suggested steps? Let me know if you need further assistance.
