lockout temps for net thermostat
franks_44
i am wanting to know the default lockout temps for the max comfort, balanced and max savings setting on my nest thermostat
Jhonleanmel
Hi franks_44,
Nest thermostat Heat Pump Balance settings are for systems that have a heat pump and auxiliary (AUX) heat. You can choose how much expensive AUX heat your system will use when your heat is running. AUX heat can cost about 2 to 5 times as much as running your heat pump.
If Heat Pump Balance is enabled, you don't have to worry about the lockout temperature. Just choose whether you want more comfort or more savings, and the Nest thermostat will learn to adjust your lockout temperature as needed. Check this link for more details.
Mel
EdwardT
Hi franks_44,
Edward
aatienza
Archie
