nest thermostat cooling issue
jk9
nest is sending only 14 v to condenser relay i checked wiring 24v power on to rc terminal
Measure the voltage at the terminal block on the control board in the furnace/air handler.
MelbaDT
Thanks for answering, Patrick_Caezza.
jk9, I wanted to check if you had the chance to try Patrick's suggestion? If yes, how was it?
Melba
MelbaDT
Hey jk9,
Checking back in — how's your thermostat now?
Melba
MelbaDT
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Melba
