nest thermostat shows as offline on nest hub display
jdogpat
i installed a Nest thermostat and downloaded the Google Home App. i also installed some smart light bulbs. everything connect to wi-fi with out any issues, i can control all the lights and the thermostat through the App on my phone. then i added a Google Nest Hub and it connected to Wifi no problem. with the hub i can control the lights and interact with google.  assistant , play music, everything except control the Nest Thermostat. I get a message on the Hub screen that the thermostat is off line. i have reinstalled both the thermostat and the hub and still have the same issues
GarrettDS
We hope you were able to get the help you need but if the issue persists feel free to create a new thread, and provide as many details as possible so that others can lend a hand.
Garrett DS
