05-13-2022 09:36 AM
I've confirmed our nest learning thermostat is indeed compatible with the Bosch Split System Heat Pump | R410A, although yesterday our Bosch installer suggested otherwise because he's never worked with nest. The installers answer to getting our system to cool is as pictured - ie: disconnecting our nest & using our breaker panel to turn the Bosch on/off. Yep. For real. Is there specific wiring or Bosch set-up in order to make this combination work? Many, many thanks in advance.
nest learning thermostat model: display 3.7 | backplate model 5.4
bosch split system heat pump R410A product specs: chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://iwae.com/media/manuals/bosch/bova-specifications.pdf
06-15-2022 02:46 PM
Hope this helps!
Kind regards,
Ryan
