11-30-2023 10:40 AM
Recently we experienced that the nest does not turn off the fan after heat cycle is complete, we were away for a few weeks, and it looks like the fan ran 24-7 . The fan run feature is disabled. It does shut off when I remove the unit form the wall. how do I reach the nest support phone number to fix this issue so i do not waste electricity.
12-05-2023 02:31 PM
Hello nr1,
It sounds like you're facing an issue with your Nest Thermostat, and I understand the concern about the fan running continuously. To get assistance with this matter, you can reach out to Nest Support through the following steps:
1. Visit the official Nest support website.
2. Navigate to the "Contact Us" or "Support" section.
3. Look for options to contact support, which may include live chat, email support, or phone support.
If you're specifically looking for the Nest support phone number, it's advisable to check the official Google Nest Help Center website.
In the meantime, if the fan continues to run without stopping, manually removing the unit from the wall to turn it off is a reasonable workaround. However, getting in touch with Nest support will help address the root cause and ensure a more permanent solution.
I hope this helps and that your Nest Thermostat gets back to operating as expected soon!
