01-08-2022 07:19 PM
The nest worked one month then dropped wifi connection, after following and doing all the solutions - every step including removing and reinstalling the thermostat it is acting weirdly. Wont heat at the designated temp, doesnt seem to be reading the house temperature correctly, we go down many degrees but it still wont turn on unless i do it manually, and now it for some reason I think it has for some reason set 80 degrees as its top setting - nothing i did ever have it go to 80, the nest used to turn orange when we walked by but not any longer. Threres probably more going on that i can not fathom at this point .
Any clues what to do next?
Twyla
