02-18-2022 07:23 PM
My nest just showed the error code "ERROR E195" No power to R wire detected. The furnace is continuously blowing but not really heating. Help what do I do?
It winter in MN!!
Sonja
02-20-2022 05:53 PM
Help
02-26-2022 08:59 AM
Thanks for reaching out and we're sorry for the delay.
Let's give this steps a try to further help:
Note: Make sure to turn off HVAC switches before touching any wire.
Ryan
03-01-2022 01:02 PM
I just wanted to follow up and see if you're still in need of help? Please let me know, as I would be happy to answer any questions you may have.
Ryan
03-08-2022 05:45 PM
Furnace will not run. Electric available at furnace & Red thermostat wire. Technician recommended touching R wire to W wire. Then furnace started. I also restarted thermostat by holding ring down for 10 sec. When restarted, temp appeared for a short time, then went back to error code.
03-14-2022 05:21 PM
Mine just started doing the same thing, did you get yours fixed?
06-13-2022 07:43 AM
Hope this helps!
Kind regards,
Ryan
