t04 forced air heat - fan will run but not heat
1Motti
My system has power, the fan test works, but not heat. Any ideas?
RenzJ
Hi 1Motti,
Thanks for bringing this up here in the Google Nest community. I'd be happy to take a look at this for you. Please answer the following:
  1. Are you from North America or Europe?
  2. What type of Nest Thermostat are you planning to have?
  3. Send us a photo of your current wiring.
  4. What is the make and model of your HVAC?
Renz
Shonda
Good morning. Having the same problem, any resolution to your problem yet
RenzJ
Hello everyone,
@Shonda, thanks for posting here in the Google Nest Community. Let’s check what’s happening with your device. Please answer my questions above.
Thanks for the update @1Motti.
Renz
1Motti
yes, I had to call a furnace guy.  I guess there was a valve stuck or something and he fixed it fairly quickly.  It wasn't a problem with the thermostat
