01-01-2024 09:11 AM
I have a question regarding my wiring compatibility:
I have a:
W/W1 wire
O/W2 wire
C wire
G wire
R wire
Will my system be compatible with any nest thermostat?
Thanks!
01-04-2024 01:14 PM - edited 01-04-2024 01:14 PM
Hi jpzxcv,
Thanks for posting here in the Community forum and for showing interest in our Nest Thermostats. Your thermostat wires could be compatible with our Nest Thermostats. Are you located in North America or Europe? Do you have a heat pump system? And could you send us a photo of your current thermostat wiring configuration so I can take a closer look? Also, you may use our Compatibility Checker to determine if a Nest Thermostat is compatible with your heating and cooling system.
Keep us posted.
