06-15-2024 04:41 AM
Any info about when the "Boost Wi-Fi 6E speed for Nest Wifi Pro" will be released?
https://support.google.com/googlenest/answer/12349124?hl=en
Thank you
06-16-2024 07:51 AM
Hello @Rice
I can't provide an official answer, but from what I can tell, the FCC just approved AFC providers in the U.S. in late February, and it sounds like Cisco is the first company to get their WiFi devices certified for use with 6GHz "standard power" in April. So, the regulatory pieces are falling into place, but Google will need to select one of the AFC providers and get their product certified before they can enable the feature. I suspect they may not be the first consumer product to get certified, though.
06-18-2024 03:48 AM
Thank you for the info. I did not understand that "boost" was really the "Automated Frequency Coordination (AFC) systems for Standard Power 6 GHz Wi-Fi". I found the FCC announcement...
However, I don't find any articles about Google's plans to implement it yet.
06-18-2024 06:13 AM
Yeah – that's the FCC approval from February I was referencing. AFC allows each WiFi system to contact one of the "providers" to see which parts of that spectrum are in use by licensed users in the same area. That way, the WiFi system (which is unlicensed) can pick a channel that avoids licensed usage nearby, and transmit at higher power on that channel without interfering. In order to do that, Google will have to collect the location of every Nest WiFi Pro that enables this feature (so I expect it to be optional). I would have hoped Google would have already implemented all of this, and would just need to get it certified. But, it's more likely they prioritized other things, and have waited until the FCC finally released its rules to get started on it. We probably won't hear anything from Google until it's "coming soon".
