Config to pass on faster connection speed
Nestnetwork
I have been using my nest wifi successfully for many months. 1 router hub and 3 slaves. This week I changed the ethernet connection to the router from 70Mbps to my new fibre service running at 300Mbps. The nest speed test via google home shows that the ethernet is correctly running at 300Mbps. But when I test my Wifi using any device is only runs at 30 to 60 Mbps and not 300.  Wifi on my ISP provided router has been turned off so only running Ethernet. I have also prioritised the Ethernet connection to the nest. DOes anyone know why my next network is not passing on the full 300Mbps ? This is even the case when I stand right next to the router.
Thanks
Dave
11 REPLIES 11
Jeff
Hey, Nestnetwork.
Sorry for the late response here, but I wanted to check in to see if you were still having this issue and to see if you have done any troubleshooting so far. If you still need help, let me know and I'll be happy to work on this with you.
Thanks.
Nestnetwork
Hi Jeff,
It seems that the nest divides the connectivity at around the house at 50Mbps from each node. I have the master connected by ethernet to my fibre router at 300 / 100 Mbps and 4 mesh nodes. Speed tests everywhere run at 40 to 50Mbps download and 15 to 20 Mbps upload.
If I test the mesh speed using google home its reads 300 / 100 Mbps
If there is a way to increase the mesh speed to devices I would be interested. Modem is from Trooli (english fibre ISP)
Thanks
Dave
Jeff
Hey, Nestnetwork.
Thanks for the added info. I have a couple of things for you to check real quick.
  • When you run the mesh test, what do you get for connection strength on your WiFi points?
  • Do you have any preferred activities set up in Google Home?
  • If you set a priority device and repeat the network test, do you see any changes in overall performance?
If you can let me know those things, I think we can move onto next steps for troubleshooting.
Thanks.
Nestnetwork
Hi Jeff,
Connection test is all good. I just set my phone as a priority device and it jumped to 150 / 100 Mbps measured at about 3m from a connection point. Thats while several other devices are active
Thanks
Dave
Jeff
Thanks for running that test for me.
This might sound a bit weird, but if you prioritize your phone and then run a speed check, do you see speeds up across the board, or only for your prioritized device?
Nestnetwork
Everything goes up a bit - by 10 - 20Mbps
But nowhere near the 300Mbps inbound speed from the router. I don't have any preferred applications set up BTW.
Jeff
Thanks for checking on that, Nestnetwork.
I'm going to have to check with an internal team on this, but out of curiosity, have you tried contacting support via phone or chat to see if they can directly diagnose your network? If not, you can do that here: https://bit.ly/3o1aRK5.
I'll report back when I hear more, but it might be a good idea for you to try speaking with support as well.
Thanks.
Jeff
Hi, Nestnetwork.
I just wanted to follow up and see if you tried contacting support and to see if you had any luck going that route. Let me know if there's more I can do here for you.
Thanks.
Jeff
Hey, Nestnetwork.
Just one more follow up real fast to see if you were able to make any progress here or to see if you still needed some help and to see if you were able to connect with support. If things are still not working right, let me know.
Thanks.
Jeff
Hi, everyone.
Thanks
