04-22-2022 05:55 PM
Hi Community.
My Nest Max, my android cell phone, my Google Home App, and my Philips Hue Bridge are ALL on the same 2.4G wi-fi network and the Philips Hue Bridge and lights are working without any issues.
What is the problem and how do I fix it (and thanks in advance for no chewing gum and duct tape quick fixes).
Also, There are sources on the internet that say my Nest Max has a temperature sensor inside it and can display the ambient room temperature and humidity of the room that the Nest is in. They say I have to turn on ambient mode for the Nest. I cannot find that mode where they say it is located. Are they failing to mention that I first have to connect a Nest Thermostat to my network?
Thanks community for any help.
05-20-2022 12:26 PM
Hey jandream,
Sorry for the late reply. I wanted to follow up and see if you are still in need of any help? Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
05-24-2022 11:24 AM
Hey jandream,
I wanted to check in and see if you are still in need of any help with your device? Please let me know, as I would be happy to assist, and answer any questions you may have.
06-30-2022 10:44 AM
Hey jandream,
Sorry for the delayed reply. Do you mind me asking if your phone is connected to either the 2.4 or 5Ghz? I did also find an article with a little more details on what you may be running into. Please let me know if that helps, or if you have any questions from here.
07-03-2022 12:06 PM
Hey jandream,
How's it going with your devices — still need out help?
Alex
07-04-2022 12:14 PM
Hi jandream,
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google speakers and we'd be glad to assist you further.
Alex
05-24-2022 12:34 PM
Hi Jake and thanks for the follow-up. Yes, I am still experiencing the same issue as described in the original message. The only thing I might have left out was that my Comcast Xfinity router is configured with 2 separate channels (2.4Ghz and 5Ghz with different names), but that has never mattered to other devices which only connect on 2.4Ghz which is where the Hue lights and the Nest Max are both connected to. I just cannot connect my Hue to my Nest Max so that I can control the lighting from the Nest.
Any ideas?
Stephen (jandream)
