06-20-2022 08:52 AM
I’ve been facing slow speed issues with my Nest Wifi Mesh. I have ATT Fiber and it shows full 500mbps at the gateway. The Main Google Wifi hardwired to the Gateway shows 590 download and the mesh connection test said “Great Connection”. However when i run speed test on different devices, it shows 40-50mbps download speed and even 15-20mbps at some times. I did not have much problem initially but now it’s affecting my work. Is Google looking into this? I saw a lot of posts with similar issues.
Gurashish
06-20-2022 01:35 PM - edited 06-20-2022 01:37 PM
Try to disable all preferred activities (QoS basically):
And make sure no devices are stuck in priority mode:
And offload Wi-Fi (a shared resource between all wirelessly connected devices) by wiring as many devices as possible + use wired backhaul between Nest Wifi pucks with ethernet ports if possible:
06-27-2022 10:37 AM
Hi, grewal12.
I just wanted to jump in real fast to see if you saw olavrb's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
- Jeff
06-30-2022 03:14 PM
Hey, grewal12.
I'm just checking in once more to see if you still needed help or to see if you're all sorted out here.
- Jeff
07-04-2022 12:20 PM
Hi grewal12,
Just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Edward
