09-30-2024 09:34 PM
We have a family group set up to pause certain devices at 8 PM.
At 8 PM, the devices correctly paused.
A short time later, we ended the schedule so the devices could be used.
An hour after that I clicked Pause on the group.
The “thinking” indicator spun for a bit then went away. The group was still not paused.
I tried this multiple times, but the group still will not pause.
Help!
10-03-2024 09:46 PM
Hi there!
Thanks for posting in the community.
I’m sorry for the inconvenience that you’ve been experiencing with the Google Nest WiFi device. I understand that you create a family group to be able to pause some devices at certain time. You created a schedule to pause some devices at 8 PM, and it worked. Some hours later, you resumed the devices, but when trying to pause them again, it was not pausing the family group. No worries, help is here.
In order to give you the correct steps, I need some extra information. Here are some questions for you:
In the meantime, you can try the next troubleshooting steps:
Please check the following articles: Create and delete groups with Family Wi-Fi for further information.
Tell me how it goes.
Daniel.
