06-09-2025 10:10 AM - edited 06-10-2025 02:47 PM
I have a 6 node Google Wifi system, somewhat dated. Model is NLA 130425 running 14150.376.32. ISP is Ting, fiber based running close to 1G symmetric. Over the last couple of months 3-4 times a week, internet begins to run very slow, <500kbps. Hard reset (power cycle) on the Google node that is connected to the TING router resolves the issue (the "master node"), and i'm back up at ~GE internet speed test (Ookla...nearest peering). Master Node is connected to Ting router via CAT6 cable. Not a device WiFi issue as when I'm in the situation, all devices experience the slowdown, independent of which Google node they are connected to, or distance from Node, and the reset of the "master" Google node resolves the issue for all devices. Any ideas on what could be causing the slowdown, and possible solutions? I appreciate your assistance. Thank you.
06-12-2025 06:44 PM
Hi jeffchang,
Thank you for reaching out to our community.
I understand that you have noticed during the last couple of months, three or four times a week, your Google Nest mesh starts to run very slow. I appreciate the troubleshooting efforts you have tried and for letting me know that your speed is less than 500 kbps, while you have close to 1 G available. Don't worry, help is here!
Before I start further troubleshooting, let me ask you a few questions:
Please keep me posted.
Virna
06-13-2025 08:04 AM - edited 06-16-2025 08:34 AM
@virnab : Thank you for your reply.
1) # of Devices: when I test, I have all of the dynamic devices off (ie: none of the kids streaming), but I have some fixed items still running (ie: smart home devices, but there's only a few, <10).
2. Modem only. ONU for Ting is Calix GP1100X GigaPoint. ONU is connected directly to Google Wifi node via Cat6, then mesh to other Google Wifi nodes.
3. No switch
4. Speed test direct to ONU modem is 945Mbps down, 940 up.
Slow down happened again yesterday. What was interesting is that my mobile device on WiFi slowed way down on one of the nodes, but then when I went downstairs and presumably starting working off another node, my speeds went signicantly up (3Mbps to 150 Mbps). Could I be experiencing a channel interference issue?
Thank you for the help and support!
06-17-2025 02:14 PM - edited 06-17-2025 04:41 PM
Hi jeffchang,
Thanks for your timely response and the comprehensive information you've provided. I really appreciate it so I can better assist you.
Based on the information you shared with us, I recommend you perform the following troubleshooting steps:
Virna
