04-25-2023 03:45 PM
This is a continuation to this thread, unfortunately I was traveling for the last 5 weeks with limited internet access so I couldn't respond in time before the thread was locked out.
The only update I wanted to provide was, I've tried everything that was suggested in the thread before I even open conversation, and I tried all of it again with no luck.
Unfortunately what worked for me was, I purchased a 50ft cat 6 ethernet cable to connect the router to the access point, and now my speed is respectable at 550mbps instead of <200mbps I was getting when I didn't hardwire. It's super disappointing that I have to hard wire, but it's better than spending > $200 getting a new system.
Thanks
04-25-2023 05:25 PM
That is the normal behavior for wifi routers/points. It's a tradeoff to use wireless for coverage. Some other brand router uses 6Ghz for backhaul to increase performance, but I believe for Nest router because it's wifi-5, and it uses 5Ghz for it, so you will lose the half capacity for connection between the router and point.
Remember nothing is more reliable than a wired backhaul. Someday, the 6Ghz channel will be full of traffic. If you want to have a stable and high-performance network connection, you have to wire them.
04-25-2023 06:09 PM
Thank you Henry, that's super insightful. I am actually losing 2/3 speed between router -> Access point.
I will plan to do a proper wiring to connect the wifi access point.
04-30-2023 10:55 PM
@henrykindle, appreciate your helpful response.
@cstriker, chiming in to ensure everything is good here. Have you had the chance to try the suggestion above? If yes, how is it?
Abi
05-03-2023 11:47 PM
Hello there,
Abi
05-06-2023 11:45 PM
Abi
05-07-2023 09:41 AM
You’re welcome to close the thread, my post had conclusions on my findings and nothing further to try.
thank you
05-07-2023 03:53 PM
Hey cstriker,
Thanks for the update. I’ll be closing this thread now. Feel free to create a new thread if you have a new concern and we’ll be here to help you out.
Abi
