Google Nest Wifi Speed Paired With Starlink Slower Than Connecting Directly
BPreston81
I live in a rural area and use Starlink for internet. I have a Google Nest Wifi Router plugged into the Starlink router and 4 access points including one Nest Wifi point and 3 Google Wifi Routers. They all communicate with each other fine but I find the speed is about half when connected to the Google Wifi versus connecting directly to the Starlink Wifi, even when sitting in the same room as the main Starlink router and Google router. Any ideas on how I can improve the speed of the Google network? I really don't want to have to breakdown and buy the Starlink mesh routers to replace the Google setup since I already had all of them before we got Starlink. Thanks for the help!
anon21234512321
Have you wired into the Starlink with the Starlink ethernet adapter? Do you have the Starlink in bypass mode?
anon21234512321
You’re a lifesaver. I didn’t have bypass mode on. We are connected via the Starlink Ethernet adaptor. But turning on bypass mode immediately improved the speed. Thank you!
Nice! Happy interneting!
Dan_A
Hi BPreston81,
We’re happy to see that anon21234512321’s instructions helped. This is noted, and we’re sure that this thread helped our Community members, too!
Just to confirm, is everything the way it should be? Do you still have any concerns or questions? Kindly let us know; we’re here to help.
Dan
