12-03-2023 03:09 PM
I had a google wifi set up of three picks (1 hub, 2 points) and they appear to have been operating in a daisy chain as the hub is at one end of the house. I recently added a further google wifi point in my garage. The garage is about 20 metres from the house and the hub is the nearest google wifi point. When I first added the point I had no issues and the signal was good for all wifi points. Recently, when I have the 4th (Garage Point) on line, the furthest wifi point in the house (my office) becomes weak. When I disconnect the wifi point in the garage, all is well again. Am I right that this is because the location of the 4th wifi point (closest to the hub) causes the mesh to work in a hub and spoke mode, meaning that the office point is too far away from the hub? Is there anyway to get around this? I can't eassily move the hub... or the garage.
Gerry
01-03-2024 02:42 PM
Hi GerryS,
That certainly isn’t the experience we want you to have, and we apologize for the delay. A few questions: are you using a modem/router combo from your Internet Service Provider (ISP)? Which Google/Nest router are we working with? What device are you using to set up your network (iOS or Android)? Do you have the Internet on your modem?
You can do a sequential reboot of your entire network and see if that helps, or please perform a 2-minute power cycle on your entire network to re-establish the connection on your connected devices. Here's how:
Also, you can give these steps a try:
You may skip any step that you’ve done already.
Let us know how it goes.
Dan
