Google seem to have boot speed test giving false reading, Mesh connection gone down
tops
Basically I had a three pack nest wifi that covered my house, Bout a 3 pack plus a extra puck and I am having problems getting weak signal/weak connection never had that with my 3 pack nest wifi. I did a speed test and im getting high readings although connection is saying weak. Readings way above what im paying for something not right.
Jeff
Hey tops,
Can you give me an idea about the placement of your points in relation to your router? If you are getting a weak connection, the speeds at your points might be on the 2.4GHz channel, which is slower than the 5GHz channel. The speed reading at your router will reflect a speed more in line of what you would be seeing at 5GHz.
Jeff
AbigailF
Hi tops,
Abi
AbigailF
Hello tops,
Abi
