02-13-2023 02:27 PM
I have had a Google wifi system setup in my house for 5 years now. It consists of 3 google wifi points one of which is the main hub. I recently installed a Philips hue bulb in my utility, however, the wifi doesn’t reach that room in order to control the bulb so I decided to purchase a second hand google wifi point to try and connect to my current setup. I have tried so many times yet I cannot get it to connect. I just get the error message in the photo I have attached to this post. Please could someone help me.
02-13-2023 05:44 PM
Try factory resetting the point The factory reset button is located on the bottom of the point. Check for a circle etched into the bottom, then: Press and hold the factory reset button on your point. After about 5 seconds, your device will begin the factory reset process.
02-13-2023 10:40 PM
Hi, do you mean the button on the back of the point? If so, I have held this down (which made the lights flash orange then turned blue then I let go of the button) I assume this was a factory reset?
02-14-2023 05:40 AM
When it's factory resetting it will make a sound letting you know it's doing so, you may need to hold the button longer. Once it makes the sound you can let go of the button
02-14-2023 06:02 AM
Thanks for that, I tried what you said but still no luck unfortunately 😟
02-18-2023 06:02 AM
Still not had any luck, I even restarted my whole system again from scratch and get the same problem
02-18-2023 05:17 PM
Thanks for lending a hand, @Ashepherdson.
@Npatmore, I’m sorry to hear you’re still having this issue. I have a few questions:
I’ll wait for your update.
Abi
02-19-2023 12:27 AM
Hi @AbigailF thanks for your response.
• It does broadcast a setup SSID but not all the time, it’s very temperamental.
• I tried wirelessly.
• the status lights on all other points are a solid white.
• It is around 25 meters away, however, I have tried setting it up directly next to the main router and still had the same issue.
• Yes, the message stated: unable to join the network “Setup 73D00”
• No, there are no switches in my network.
I am using an iPhone 14 pro and have a virgin media hub 4 as my main internet router which is connected via Ethernet cable to my main google wifi router which I have 2 separate google wifi points. It’s the 3rd point which I cannot connect.
02-26-2023 07:07 PM
Hello Npatmore,
Thanks for the update. Could you confirm if you were able to do the steps regarding factory reset below?
The factory reset button is a circle etched into either the bottom or back of the device.
We'll wait for your update.
Abi
03-01-2023 07:12 PM
Hi Npatmore,
Abi
03-02-2023 02:08 PM
the google wifi point has never appeared in my google home app as it is a second hand point I purchased from ebay which has never been setup on my wifi network before. I tried all the other steps and still get the same error message.
kind regards,
Nathan
03-07-2023 09:21 AM - edited 03-07-2023 09:22 AM
@Npatmore, go ahead and try the steps below to add your Google Wifi to your mesh network.
Let me know how it goes.
Lovely
03-10-2023 10:29 AM
Hey Npatmore,
I'm checking back in. Were you able to do the steps above? I'd be glad to hear from you to make sure everything is working.
Lovely
03-22-2023 02:04 PM
Hello ttantrum11,
Sorry for the delayed response. Please follow the steps I provided above. If you already did, uninstall and reinstall your Google Home app before going through the setup process. You may also use another phone or tablet to set up the device.
Keep me posted.
Lovely
03-25-2023 03:22 PM
Hello ttantrum11,
How's it going with your Google Wifi point? Were you able to add it to your mesh network? Don't hesitate to reply to this thread if you still need help.
Lovely
03-26-2023 08:04 PM
Hey everyone,
Thanks for the help, @LovelyM.
Abi
03-10-2023 12:05 PM
Good afternoon
I am having the same problem here. I have an IOS device. I bought a point from eBay and want to add it to my wifi network. I am getting a " connection failed message. I already tried the factory reset steps and I have the solid blue light that sometimes switches to a flashing white.
03-10-2023 12:07 PM
