How to perform DNS rebinding on nest hub and nest mini (not google wifi) because my ISP block google
abellaj
Disclaimer: This thread was migrated from our previous version of the Google Nest Community.  You can continue to receive updates on your thread issue here or simply ask, browse or more in the new Google Nest Community.
Original Poster:FDm
My ISP block google DNS so that my nest mini, nest hub, and old google home speaker cannot connect to my ISP. I found at google support that google wifi has its setting to modify DNS so that I bought google WIFI especially for this purpose.
The problem is, my google Wifi seems to be ok because I can change it into my ISP DNS. But still my google home speaker, nest mini, and nest hub cannot connect to my ISP eventhough I have set up my google mesh wifi with my ISP's DNS.
I think google has set DNS rebinding as default on nest hub, nest mini, and old google home speaker. How do disable DNS rebinding on these devices?
Jeff
Hi, FDm.
Sorry to hear about the issues you're having with your ISP and the DNS addresses. I'm sure it's frustrating to have to deal with that. Let's see what we can do to get things working 100% for you.
You mentioned that your ISP was blocking Google's DNS. Have you spoken with them about why they are doing that? In most cases, if you contact your ISP and explain to them that your network devices need access to a specific DNS set, they will unblock that for you. Before trying to get too deep into using different addresses and configurations, I would call them and see what they can do for you.
If you are unable to find any luck with the ISP directly, please let me know and we'll see what we can do on our end.
Thanks.
Jeff
Hey, FDm.
I'm just following up to see if you saw my reply and if you were able to get this sorted out. Let me know if there's anything else I can do here.
Thanks.
Jeff
Hi, everyone.
Thanks
