How to set up using 3 separate LAN lines
A061670
I have 3 LAN ports in 3 different rooms, I’d like to hard wire each Nest Point. How do I go about setting that up?
David_K
Be sure which model you have. Nest Wifi points don't have an ethernet port and can't be hardwired. Nest Wifi Pro, Nest Wifi router and the older Google Wifi point does have an ethernet port and can be hardwired. Either way, your modem's LAN port connects to your Nest Wifi router or primary Google Wifi point's WAN port.
To hardwire your other points, you can either chain them together or use a non-managed switch:
  • Modem → Wifi router → Point → Additional point → and so on
  • Modem → Wifi router → Switch → Point → Additional point
  • Modem → Wifi router → Point → Switch → Point → Additional point
More details:
Hardwire Wifi devices with Ethernet - Google Nest Help
AbigailF
Thanks for lending a hand, @David_K.
@A061670, I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Abi
AbigailF
Hi A061670,
We’d like to check in again in case you have any further questions or concerns. Feel free to reply to this thread and we’ll help you out.
Abi
AbigailF
Hello A061670,
Abi
