09-04-2022 04:46 PM
So I have a nest wifi setup with 1 router and 2 points. This is a well established network and we have not had any issues for some time, but my mother has recently tried to connect to the network and it seems to connect fine, but her phone is showing no network connection. If you go to YouTube it says no connection at the bottom and the network seems to be down. But every other device on the network work just fine. The phone says connected to the WiFi but the wifi point says the device is offline.
09-05-2022 04:15 AM
Does she have MAC randomization enabled? Try to disable that.
Does she have Apple iCloud Private Relay enabled? Try to disable that too.
09-11-2022 11:56 AM
I hope you've got the answer you're looking for. If you're still in need of any assistance, feel free to let us know.
Mel
09-07-2022 06:46 PM - edited 09-07-2022 06:46 PM
Appreciate your helpful responses, olavrb.
landoman1, chiming in to ensure everything is good here. Have you had the chance to try the suggestion above? If yes, how is it?
Mel
09-12-2022 12:11 PM
Mel
