09-02-2022 11:37 PM
Hi all, I am more knowledgeable than my wife on WiFi/routers etc but nowhere near some of you guys so any help would be really appreciated!!!
Q1 - I have a Google WiFi 3 pack and have just bought a nest router/point pack! My wife works from home and uses zoom loads and most of the time it's ok but we occasionally get problems where the picture/sound drops! If I connect her laptop to the guest network (with no other devices on that network) instead of the main one, will there be less interference as the laptop will be the only device using it? Are the guest and main network completely separate?
Q 2 - my mesh network is currently setup as a Google WiFi router connected to the modem on the lounge and a point in the kitchen and office.....I was thinking of connecting the nest router in the lounge and then using the Google router in the office as a point as it has ethernet and then placing the nest point somewhere else! Any suggestions to improve this setup or is it the best it can be?
Many thanks for anybody that replies!!!
09-03-2022 08:24 AM
Ok thanks very much Michael P...I'll have a tinker with things and see what I can do! Thanks again for your help!!
09-10-2022 10:56 AM
No all good thanks EdwardT!
09-03-2022 07:15 AM
Hello @Paul-76
Just a note that I moved this message to create a new thread in hopes of getting more focused discussion on your questions.
Regarding your first question, the main and guest WiFi networks use the same radios (both 2.4GHz and 5GHz) as each other. They just have different network names and passwords in addition to some other higher level security features. The interference and performance should be exactly the same since they'll still be sharing the same channels. Regarding intermittent performance issues, that can be hard to diagnose since there are so many things that could be contributing to it. I always start with a mesh test to ensure all of the secondary / mesh point units are showing a "great" mesh quality. If any of them aren't move them closer to the primary and re-run the test. Another suggestion is, since you are using Google WiFi now, and those units have Ethernet ports, you can connect her laptop to a nearby Google WiFi secondary via an Ethernet cable to skip one WiFi "hop" in the path. Obviously, this has implications regarding placement and convenience. Anyway, those are just a couple of ideas.
Regarding your second question, The Nest WiFi Router hardware does have a bit better WiFi radio than the Google WiFi hardware, but it may not be better in a way that matters under most conditions. But, if using it frees up a Google WiFi unit to use somewhere that having Ethernet would be helpful (e.g., see above), then it might be worth it. However, be aware that doing this will require performing a complete factory reset of all your existing units, then setting up the Nest WiFi Router unit as a new primary and then adding all of the old units one by one to the new network. You can (and should) use the same network name and WiFi password so at least your clients won't have to be reconfigured, but it will still be a fair amount of work. An alternative would be to add the Nest WiFi Router unit as if it were a secondary / point to your existing network. But, I'm a little confused, since you say you already have a Google WiFi unit in your office – why not just use the Ethernet ports on that unit where it is already? All of the Google WiFi units are the same in terms of hardware – the one that acts as a primary / router is just the first one you set up and connect to your internet service via Ethernet.
Lastly, the Nest Point unit will need to be placed close enough to the primary (whether that's the existing Google WiFi primary / router or the new Nest WiFi Router unit). Sometimes more access points isn't better, and can even be worse.
I hope some of this helps!
09-03-2022 08:09 AM
Thank you so much for your reply Michael P! If I left my three goole WiFi units as they are, router and two points and then connected the nest router to my modem and a point somewhere else, would that create a new network where my wife's laptop could be the only thing connected to it? So basically my original Google points on my network and the nest ones on my wife's network? I gather I would need to create another Google home for the nest WiFi to live?? Is that possible??
09-03-2022 08:21 AM
Assuming your modem is actually also a router with multiple Ethernet ports, then you could set up a new Nest WiFi Router and Point with a different network name and password (and yes, it would need to be in a different "Home" in the Google Home app). However, I don't know that it would perform any differently, since it would still be sharing the same 5GHz WiFi channel as your existing Google WiFi system. So, yes, it's possible. But, it is unlikely (in my opinion) to improve things significantly.
09-03-2022 08:24 AM
09-05-2022 07:34 PM
09-08-2022 07:36 PM
Hi Paul-76,
Edward
09-09-2022 07:38 PM
Hi Paul-76,
Edward
09-10-2022 10:56 AM
09-12-2022 01:03 PM
Thanks for letting us know, Paul-76. I'm happy to see all is worked out for you.
Jeff
