04-06-2024 12:51 PM
I found older posts about how Starlink and google mesh just stopped working together but nothing with a solution.
it worked great for a year or so, then all the sudden I go from 160mb/s on starlink but once I hook my nest mesh back up we’re in the mid 20s/sec. I know I’m not the only one who had issues but is there a fix yet?
I don’t know what happened but I wish it would fix itself
04-17-2024 01:21 PM
Hi BradZ,
Thanks for reaching out. I'm sorry to hear you're experiencing slowdowns with your Nest mesh after connecting it to Starlink.
Starlink and Google mesh can work together, but there can be some compatibility issues that lead to slowdowns or connection problems.
Here are some things you can try:
Hope this information helps.
Sincerely,
Jonathan
