2 weeks ago
Hi folks, I have. Nest wifi setup with a router and 2 wifi points. Can I add another router as a wifi point and plug a lan cable into that to use for a pc feed?
2 weeks ago
Hello @Sashalamont
Yes, you can add another Nest WiFi Router (or a Google WiFi unit) as a point/secondary and use the Ethernet ports on it to connect wired devices via Ethernet. When you set it up in the Google Home app, just make sure to tell the app you're setting up a Point unit, not a Router.
