Low device speed
Bugbug
My Sony Bravia tv reports extremely slow speed (60mbps with lots of buffering, paused streaming across all apps, etc ) while the network reports blazing fast (900+) and devices fast (500+). The closest wifi device is less than 20ft away with no obstruction. I've tried speed tests, disconnecting & reconnecting, rebooting, etc. but that's about the extent of my tech savviness. Any suggestions on what might be causing this issue and what I might be able to do to troubleshoot are welcome!
RXShorty
Hi @Bugbug
Most TV's dont have a good Wifi card.
Did you try setting your TV as an priority device within the Nest Wifi setup?
Check THIS link.
Jeff
Thanks for the info, RXShorty.
Hi Bugbug,
I just wanted to jump in real fast to see if you saw RXShorty's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Jeff
Jeff
Hey again Bugbug,
I just wanted to follow up once more to see if you were still needing some help here. If so, just let us know.
Jeff
Jeff
Jeff
