02-26-2022 09:48 PM
Are there circumstances where i can exceed the 5 point limit without them interfering with each other? I'm trying to extend wifi through a long house with multiple rooms. For the most part, each point will only be able to communicate with two other points. as an example (p1)--(p2)--(p3)--(p4)--(r1)--(p5)--(p)6--(p7) where each (p) is a point and (r) is the router. The points at the far ends of the house won't be able to "see" each other.
02-28-2022 09:05 AM
Thanks. It does seem to be at the point where AP's make more sense.
02-27-2022 04:57 AM
Interested in the responses, long house too. Trying to understand if the points transfer the signal to the next point or if each point needs to access the router
02-27-2022 05:22 AM
With that many I'd at least use wired backhaul between the points.
Relevant doc on placement and amount of pucks:
02-27-2022 08:39 AM
Hello @MFord
I've talked about this in more detail in the past, but the short version is that this is not a recommended configuration. The nodes use a "fewest hops" approach to getting traffic to its destination, so even if they can only get a weak connection, they will use that instead of going through another intermediate node. Since there's only one 5GHz channel, each extra hop would use more channel capacity, so even if they used another path selection policy, it wouldn't necessarily be any faster. As @olavrb suggested, a wired interconnect will be significantly more reliable in a situation like this. Having the primary/router unit centrally placed will help in a wireless-only mesh, though – it just won't be enough if the most distant nodes really are far away. Only wiring is going to make that satisfactory.
02-27-2022 06:48 PM
If I go with a wired connection does that eliminate the 5 point limitation? The house seems to be lined with aluminum foil they way it attenuates wifi so I may need a lot of points. Does it matter if I "daisy chain" points or should each one be on a home run to a switch? Still trying to get me head around the topology.
Thx, Morgan
02-27-2022 10:53 PM - edited 02-27-2022 10:54 PM
Daisy chain works, but all being directly connected to the unmanaged switch is preferred. Mostly because with daisy chain, if node 3 have problems, 4 and 5 will be affected too. And because the backhaul traffic will be much greater between 1 and 2 (adds up from 3, 4 and 5) than between 4 and 5.
02-28-2022 07:50 AM
I agree with @olavrb regarding the daisy-chain vs direct wired approach. That said, I like to build a branching Ethernet network, with an 8-port core switch feeding runs to other areas of the house where I then connect 5-port and 8-port switches to feed other things nearby. You may be able to do something similar to avoid having to run long cables all the way back.
As for your first question, I can't guarantee it will work to deploy more than 5 points when they are all wired. I have heard from some others that it can work, but if you are convinced you will need this many points, you might consider another product that better fits the scale you require.
02-28-2022 09:05 AM
03-04-2022 09:24 AM
Hi, MFord.
It looks like MichaelP and olavrb were able to help you out here. I wanted to touch base and see if there's anything else you needed here. If you need anything at all, just let me know.
Thanks!
03-07-2022 12:54 PM
Hi, everyone.
Thanks.
03-08-2022 02:26 PM
Hi, everyone.
Thanks
