03-14-2022 09:03 PM
Hi, can anyone help me Temporarily switch to 2.4 Fwy to set up a garage door opener that requires 2.4 only to set up?
03-15-2022 05:06 AM
Not possible. Either buy a cheap access point that can do 2.4ghz SSID only, connect it by cable to Nest Wifi. You could also repurpose an old router for this.
Or buy a different Wifi solution than Nest Wifi.
It has been like this for years, and Google does not seem to have any plans changing it.
03-21-2022 10:44 AM
Hi, francog.
I just wanted to jump in real fast to see if you saw olavrb's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Thanks.
03-21-2022 11:58 AM
hank you Jeff for your response and open to helping me, appreciate that gesture.
03-22-2022 11:16 AM
Thanks for the update, francog. Hopefully this works out for you. Feel free to chime in if you need anything else.
Thanks.
03-30-2022 02:53 PM
Hey, francog.
No worries if you haven't had a chance to check yet, but I wanted to follow up to see that extender worked out for you. If you're still seeing issues, just let me know.
Thanks.
04-04-2022 02:29 PM
Hi again, francog.
I just wanted to check in once more to see if everything worked out for you or to see if you still need more help. Let me know where things are at for you.
Thanks.
04-15-2022 12:07 PM
Hi, everyone.
Thanks.
04-19-2022 03:53 PM
Hi, everyone.
Thanks
