11-07-2022 03:25 PM
Please give a thumbs up to this response so that more people find it.
I use Google Nest WiFi a lot. I support WiFi for 16 sites of a non-profit organization in Ontario, Canada. In addition I am a manager for 5 families with Google Nest WiFi. So that's over 60 Google Nest APs worldwide.
The 16 sites in Ontario, Canada are spread over a 200 km radius.
Some (less than 10%) of the sites have the old hockey-puck shaped AC-1304 models (original Google WiFi). The first of these were installed in 2019.
But most (more than 90%) are the Google Mesh AP/speaker combo. For these, the router is AC2200 (shows up as H2D in Settings) and the Points are AC1200 (shows up as H2E in Settings).
I have never had an issue with the older AC-1304 models. But over half of the sites with AC2200 have APs that go Offline within a week of rebooting. Reports of APs going offline have increased in 2022. It wasn't so bad in 2020 and 2021.
Troubleshooting steps, based on numerous sessions with Google Nest WiFi Support, include:
I have worked in technical roles at Cisco, Juniper, and HPE, and know a thing or two about networking. Google Nest WiFi is obviously not an enterprise-grade solution. It is a home-grade solution. You get what you pay for. Nobody is debating that. However, stable reliable performance is what every consumer demands. It should not require a physical reboot every few days. These are not supposed to be Windows 95-like devices. One should be able to expect a reasonable level of quality from these devices.
It is pretty clear to me that Alpha (of Killed By Google infamy) has diverted Engineering investment away from Nest WiFi, leaving their customers with bricks.
I challenge Google Nest WiFi Product Management to come to this forum and address this comment with a roadmap for software support of these devices.
01-08-2023 07:04 PM
Hello Leej,
Thanks for the update. We understand your frustration about the issue. I've gone ahead and sent a follow-up to the support team handling your case. Rest assured that you will be getting a reply from them shortly. I'll keep this thread open so you can send updates here as well.
Abi
01-11-2023 07:17 PM
Hey Leej,
Our senior support has sent you an email and they're waiting for your update. If you have any other concerns or clarifications, feel free to reply to this thread and we’ll help you out.
Abi
01-13-2023 10:24 AM
I'm just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns as I will be locking this thread after 24 hours.
Mel
