a month ago
Just got 2 nest Wi-Fi routers.. first connected to my t- mobile Wi-Fi router but second point model h2d won’t hook up even 20 feet away
4 weeks ago
I too took advantage of what I thought was a good offer from T-Mobile Home Internet, and ordered what I assumed were Google Mesh Router & Point system...but received only routers. Take a look at both your units...the point should have speaker holes around the bottom - and not have Ethernet ports. It seems they are sending out only Routers under their promotion.
4 weeks ago
Just found this post on how to use multiple Nest Wi-fi routers for your home....https://blinqblinq.com/can-you-use-two-google-nest-wifi-routers-together/
Hope this helps....but note I am guessing you don't have a point unit but a second router.
3 weeks ago
Appreciate your helpful response, @chris_c.
@Jdbelton02, apologies for the late reply. Thanks for posting ― let's see what's happening.
A few questions:
Does the Google Wifi point in question broadcast a setup SSID? You can check by going through your phone’s list of Wi-Fi networks.
Did you try setting up your Google Wifi point wirelessly or through a wired connection?
What’s the color of the status lights on the other router that was set up successfully?
You mentioned that your point is 20 feet away. Are you able to set it up nearer where the main Nest Wifi router is?
Did you get any message on the Google Home app during setup?
Do you have any switches in your network?
Abi
3 weeks ago
Hi Jdbelton02,
Abi
3 weeks ago
Just one quick final check in here since activity has slowed down. We haven't heard from you in a while so we'll be locking this thread if there is no update after 24 hours. If you have any new questions, updates or just a discussion topic, feel free to start a new thread in the Community.
Mel
