09-26-2023 01:42 PM
Just connected Google Nest Wifi Pro (2-Pack) to my AT&T 5268AC. It all seems to be working fine. Just want to have the optimal settings to maximize speed. What changes are needed to the 5268AC and what is needs to be changed on the Google Home app? Simple detailed steps please. Thanks!
09-26-2023 11:50 PM
The only thing you should really do is to make sure you avoid double NAT by putting the AT&T box into bridge mode / bypass mode / passtheough mode. Search AT&T for guidance on how to do that. More on why you'd like to avoid double NAT:
Other than that; performance is greatly affected by placement of the units ( https://support.google.com/googlenest/answer/7183150?hl=en ), and using the correct amount of units ( https://support.google.com/googlenest/answer/7182840?hl=en ); too many is not good either.
