Nest WiFI Pro - Do bands get split up when using Guest Network?
EWTLTD
When i turn on a guest network, do both networks use all the same bands or does the Guest Network use a specific band?
Thanks!
MichaelP
Hello @EWTLTD
The guest network supports all three bands (2.4GHz, 5GHz, and 6GHz) on the Nest WiFi Pro, just like the main network.
EWTLTD
That is what u thought too,  however cannot play my AirPlay 2 speakers on guest network, they have to be on main.
I separated IOT devices to main and use guest for personal devices only because I can use all iot devices on guest network.
any Insights?
MichaelP
That's not a band separation issue. More likely it's that the guest network may be isolating clients from each other and from devices on the main network. I like putting some IoT devices on my guest network, too, but anything that requires dynamic discovery or streaming will work better on the main network.
EWTLTD
Correct. All my IOT is on main and all personal will stay on Guest.
drawback: guest network 1/3 slower than main network.
