05-15-2023 11:53 PM
My Nest WiFi pro keeps losing IPv6 address after several hours. I have to disable IPv6 and then re-enable it in the network settings to get it again. But after several hours, it loses it again.
I'm using Xfinity. Does anyone have a similar issue?
05-16-2023 07:47 PM
Hello pbby21,
Thanks for posting. I’m sorry to hear about your issue and I’d like to help out. To confirm, are you using a modem router combination? If yes, is it bridged or not? I’ll wait for your update.
Abi
05-16-2023 08:23 PM
Hello AbigailF,
Yes, I'm using XFI ADVANCED GATEWAY (XB7) in the bridge mode.
05-20-2023 10:31 PM
Thanks for the update. Could you connect a device that’s capable of utilizing IPv6 directuly to your modem router? Please check if the device can get an IPv6 address. Let me know how it goes.
Abi
05-22-2023 10:34 AM
Yes, it can get IPv6. Even a toggling the IPv6 option from Home App brings IPv6 back.
05-23-2023 08:43 PM
Hi pbby21,
I'm sorry to hear that you're still having an issue with your Nest Wifi Pro. We'd like to take a deeper look into this — could you fill out this form and let us know once you're done?
Abi
05-23-2023 08:47 PM
Thanks, but I already reached out to the Nest Customer Care Team and they're looking into this issue.
05-24-2023 03:23 PM
That's great to hear. Could you provide the case ID number of your interaction with our team so I can check as well? I'll wait for your reply.
Abi
05-27-2023 03:28 PM
Hi pbby21,
Dan
05-28-2023 03:33 PM
Dan
05-28-2023 03:37 PM
06-02-2023 09:23 AM
Hello there pbby21,
It looks like you are already in contact with the agent handling your case. You should receive an update soon since it's already been consulted with our senior specialist team. Please let me know if you need anything since I'm going to lock this thread within 24 hours. If you have further concerns, please feel free to create a new post.
Many thanks,
Lovely
